One VariancePower and Sample Size |
Ratio refers to the ratio between the comparison variability and the hypothesized value. A ratio close to 1 suggests equality between the comparison and null variability values. Of course, you never actually know these values when you conduct an experiment. Nonetheless, it is important to consider the ratio between variability values that you are interested in being able to detect.
Test for One Standard Deviation
Testing StDev = null (versus ≠ null) Calculating power for (StDev / null) = ratio α = 0.05
Sample Size Power Ratio 50 0.8 1.31620 50 0.8 0.74353 50 0.9 1.38104 50 0.9 0.71319 |
For the lumber data, the manager wants to know what ratio between variability values he can detect with a sample size of 50 and power of 0.8 or 0.9. The results indicate that:
