Increasing the power of the test
There are three basic factors that can increase the power of a test
of two proportions:
· a
larger effect size - The greater the real difference
between proportion 1 and proportion 2, the more likely it is that the
sample proportions will also be different.
· a
higher a-level (the level of significance)
- If you choose a higher value for a, you increase the probability of rejecting the
null hypothesis, and thus the power of the test. (However, you also increase
your chance of type I error.)
· larger
sample sizes - The more observations there are
in your samples, the more confident you can be that the sample proportions
represent the population proportions. Thus, the test can be more sensitive
to smaller differences.
The most practical way to increase power is often to increase the sample
size.
If appropriate, you may also consider using a directional hypothesis.
A directional hypothesis has more power to detect a difference in the
specified direction, but has no power at all to detect a difference in
the opposite direction.
