Two-Sample Poisson RatePower and Sample Size |
The 2-sample Poisson rate procedure conducts a hypothesis test for the difference between the occurrence rates of two Poisson distributions.
Minitab's power and sample size capabilities allow you to examine how the following test properties affect each other:
If you provide values (or sets of values) for any two of these properties, Minitab will calculate the associated values for the remaining property.
By default, all calculations are based on an a-level of 0.05. However, you can select any value between 0 and 1.
Data Description |
You are an analyst for the postal service, and you want to compare two post office branches to determine which has the greater daily rate of customer visits. The historical rate is 250 customers per day, and a difference of 10 customers per day is meaningful.
