Sample Size for Tolerance IntervalsCalculating Sample Size - Nonparametric Method |
Minitab also calculates sample size using the nonparametric method. The results for the nonparametric method include the following:
Method
Confidence level 95% Percent of population in interval 95% Margin of error probability 0.05
Sample size for 95% Tolerance Interval
Margin Normal Nonparametric Achieved Achieved Error of Error Method Method Confidence Probability 1% 2480 4654 95.0% 0.049 2% 525 1036 95.1% 0.048
Achieved confidence and achieved error probability apply only to nonparametric method. |
The results of the sample size calculations show that, to achieve a margin of error of 1% using the nonparametric method, you need to collect 4654 observations. With 4654 observations, the achieved error probability is 0.049. In other words, the probability that a tolerance interval will contain 96% or more of the population is only 0.049.
If you are willing to accept a 2% margin of error, then you need only 1036 observations for the nonparametric method. With 1036 observations, you achieve a confidence level of 95.1% and an error probability of 0.048.
