Time series plots versus other plots
You can create several plots to display data collected in chronological
order:
· Time
series plot - Use when you want to examine trends
in your data over time. You can use time series plots in conjunction with
other time series functions, such as forecasting.
· Area
graph - Use to view a series of data divided into
categories. Minitab plots time series data on the y-axis versus time on
the x-axis, and shades the space below each line. Data are stacked, displaying
the proportion each series contributes to the whole.
· Control
charts - Use to detect out-of-control
points for variable or attribute data collected over time.
· Scatterplot
- Use when your data are not chronologically
ordered, or if the data collection intervals are irregular. You will need
to provide the time values along with the time series
data.
