Winters' Method (Multiplicative)
Summary
Use Winters' multiplicative method to smooth the data in a time series, and to provide short to medium range forecasting. For example, you might want to predict the temperatures for the next 6 months using the data in a time series containing successive temperatures in a city over the past 48 months. Or you might want to predict the sales of a certain type of sport equipment over the next 4 months using data collected over the past 3 years (36 months).
Use Winters' multiplicative procedure when
·    You have data with or without trend
·    You have data with seasonal pattern
·    The magnitude of seasonal pattern is proportional to data, consistent with the model when the seasonality is multiplied by the trend
·    The series does not include any missing values
·    You want short to medium range forecasting
The procedure can be used when both trend and seasonality are present and are multiplicative.
Data Description
You wish to predict water usage charges in a small school district. Bimonthly data were collected over the past 21 billing periods and these data will be used to make predictions over the next 3 periods. You also collected bimonthly data on electric usage charges.
Data: WaterCharges.MTW (available in the Sample Data folder).
Related Charting Tools
