Example of gage R&R study (nested)
In this example, three operators each measured five different parts twice, for a total of 30 measurements. Each part is unique to operator; no two operators measured the same part. You decide to conduct a gage R&R study (nested) to determine how much of your observed process variation is due to measurement system variation.
1    Open the worksheet GAGENEST.MTW.
2    Choose Stat > Quality Tools > Gage Study > Gage R&R Study (Nested).
3    In Part or batch numbers, enter Part.
4    In Operators, enter Operator.
5    In Measurement data, enter Response.
6    Click Options. Under Process tolerance, choose Upper spec - Lower spec, and enter 10.
7    Click OK in each dialog box.
Session window output
Gage R&R Study - Nested ANOVA
Gage R&R (Nested) for Response
Source           DF       SS       MS        F      P
Operator          2   0.0142  0.00708  0.00385  0.996
Part (Operator)  12  22.0552  1.83794  1.42549  0.255
Repeatability    15  19.3400  1.28933
Total            29  41.4094
Gage R&R
                            %Contribution
Source             VarComp   (of VarComp)
Total Gage R&R     1.28933          82.46
  Repeatability    1.28933          82.46
  Reproducibility  0.00000           0.00
Part-To-Part       0.27430          17.54
Total Variation    1.56364         100.00
Process tolerance = 10
                                Study Var  %Study Var  %Tolerance
Source             StdDev (SD)   (6 × SD)       (%SV)  (SV/Toler)
Total Gage R&R         1.13549    6.81293       90.81       68.13
  Repeatability        1.13549    6.81293       90.81       68.13
  Reproducibility      0.00000    0.00000        0.00        0.00
Part-To-Part           0.52374    3.14243       41.88       31.42
Total Variation        1.25045    7.50273      100.00       75.03
Number of Distinct Categories = 1
Gage R&R (Nested) Report for Response
Graph window output
Interpreting the results
Look at the %Contribution columns for Total Gage R&R and Part-to-Part. The percent contribution for differences between parts (Part-To-Part = 17.54) is much smaller than the percentage contribution for measurement system variation (Total Gage R&R = 82.46). The %Study Var column indicates that the Total Gage R&R equals 90.81% of the study variation. So, most of the variation is due to measurement system error; very little is due to differences between part. See Guidelines for measurement system acceptability.
A 1 in number of distinct categories tells you that the measurement system is not able to distinguish between parts. See Number of distinct categories statement.
Look at the Components of Variation Graph - located in upper left corner. Most of the variation is due to measurement system error (Gage R&R), while a low percentage of variation is due to differences between parts.
Look at the X Chart - located in the lower left corner. Most of the points in the X chart are inside the control limits when the variation is mostly due to measurement system error.
Calendar with week numbers
US Federal Holidays
Australia Public Holidays
