Graph > Bar Chart > choose Bars represent: Values from a table > choose One column of values - Cluster > OK
Use to chart summary data, clustered by grouping variables.
Graph variables: Enter one or more columns of summary data. Minitab displays a separate graph for each column. (To panel all graphs on the same page, use Multiple Variables.)
Categorical variables for grouping (1-4, outermost first): Enter one to four columns of grouping (categorical) variables. Minitab displays all groups on the same graph. The first variable is outermost on the scale and the last variable is innermost. (To panel by one or more variables, use By Variables.)
Tip |
By default, categories on the bar chart display in the same order as they appear in the worksheet. If you want your text categories to display in a different order, you can set a user-defined value order for the variable. See To order values in a text column by defining your own order. You can hide groups with no data (missing as a group). See Group Options. |
