1 Choose Graph > Bar Chart.
2 From Bars represent, choose A function of a variable.
3 Under One Y, choose Stack. Click OK.
4 From Function, choose a function.
5 In Graph variables, enter one or more columns of data. Minitab displays a separate graph for each column.
6 In Categorical variables for grouping (2-4, outermost first), enter two to four columns of grouping (categorical) variables. The first variable is outermost on the scale and the last variable is innermost.
7 Make sure that Stack values of last categorical variable is checked.
8 If you like, use any dialog box options, then click OK.
