Graph > Bar Chart > choose Bars represent: A function of a variable > choose One Y - Stack > OK
Use to chart a function of a variable, clustered/stacked by grouping variables.
Function: Choose a function.
Graph variables: Enter one or more columns of data. Minitab displays a separate graph for each column. (To panel all graphs on the same page, use Multiple Variables.)
Categorical variables for grouping (2-4, outermost first): Enter two to four columns of grouping (categorical) variables. Minitab displays all groups on the same graph. (To panel by one or more variables, use By Variables.) The first variable is outermost on the scale and the last variable is innermost.
Stack values of last categorical variable: Check to stack the categories for the last categorical variable. Each category is represented by a separate segment of a bar.
