Stat > Reliability/Survival > Distribution Analysis (Right Censoring) > Distribution ID Plot
Use Distribution ID Plot (Right Censoring) to determine which distribution best fits your data by comparing how closely the plot points lie to the best-fit lines of a probability plot.
Minitab also provides two goodness-of-fit measures to help you assess how the distribution fits your data:
You can display up to 50 samples on each plot. All the samples display on a single plot, with different colors and symbols.
Variables: Enter the columns of failure times. You can enter up to 50 columns (50 different samples).
Frequency columns (optional): Enter the columns of frequency data.
By variable: If all of the samples are stacked in one column, check By variable, then enter a column of grouping indicators.
Use all distributions: Choose to have Minitab fit all eleven distributions.
Specify: Choose to fit up to four distributions.
Distribution 1: Check and choose one of eleven distributions: smallest extreme value, Weibull (default), 3-parameter Weibull, exponential, 2-parameter exponential, normal, lognormal, 3-parameter lognormal, logistic, loglogistic, or 3 parameter loglogistic.
Distribution 2: Check and choose one of eleven distributions: smallest extreme value, Weibull, 3-parameter Weibull, exponential, 2-parameter exponential, normal, lognormal (default), 3-parameter lognormal, logistic, loglogistic, or 3-parameter loglogistic.
Distribution 3: Check and choose one of eleven distributions: smallest extreme value, Weibull, 3-parameter Weibull, exponential (default), 2-parameter exponential, normal, lognormal, 3-parameter lognormal, logistic, loglogistic, or 3-parameter loglogistic.
Distribution 4: Check and choose one of eleven distributions: smallest extreme value, Weibull, 3-parameter Weibull, exponential, 2-parameter exponential, normal (default), lognormal, 3-parameter lognormal, logistic, loglogistic, or 3-parameter loglogistic.
