Nonparametric Analysis Overview
Minitab provides the following types of nonparametric procedures:
·    1-sample median test (sign test and Wilcoxon test)
·    2-sample median test (Mann-Whitney test)
·    Analysis of variance (Kruskal-Wallis, Mood's median, and Friedman test)
·    Test for randomness (runs test)
·    Pairwise statistics (pairwise averages, pairwise differences, and pairwise slopes)
Parametric implies that a distribution is assumed for the population. Often, an assumption is made when performing a Hypothesis test that the data are a sample from a certain distribution, commonly the normal distribution. Nonparametric implies that there is no assumption of a specific distribution for the population.
An advantage of a parametric test is that if the assumptions hold, the power, or the probability of rejecting H0 when it is false, is higher than is the power of a corresponding nonparametric test with equal sample sizes. The nonparametric test results are more robust against violation of the assumptions. Therefore, if assumptions are violated for a test based upon a parametric model, the conclusions based on parametric test p-values may be more misleading than conclusions based upon nonparametric test p-values. See [1] for comparing the power of some of these nonparametric tests to their parametric equivalent.
Tests of population location
These nonparametric tests are analogous to the parametric t-tests and analysis of variance procedures in that they are used to perform tests about population location or center value. The center value is the mean for parametric tests and the median for nonparametric tests.
·    1-Sample Sign:- performs a 1-sample sign test of the median and calculates the corresponding point estimate and confidence interval. Use this test as a nonparametric alternative to 1-sample Z and 1-sample t-tests.
·    1-Sample Wilcoxon:- performs a 1-sample Wilcoxon signed rank test of the median and calculates the corresponding point estimate and confidence interval. Use this test as a nonparametric alternative to 1-sample Z and 1-sample t-tests.
·    Mann-Whitney:- performs a hypothesis test of the equality of two population medians and calculates the corresponding point estimate and confidence interval. Use this test as a nonparametric alternative to the 2-sample t-test.
·    Kruskal-Wallis:- performs a hypothesis test of the equality of population medians for a one-way design (two or more populations). This test is a generalization of the procedure used by the Mann-Whitney test and, like Mood's median test, offers a nonparametric alternative to the one-way analysis of variance. The Kruskal-Wallis test looks for differences among the populations' medians.
The Kruskal-Wallis test is more powerful (the confidence interval is narrower, on average) than Mood's median test for analyzing data from many distributions, including data from the normal distribution, but is less robust against outliers.
·    Mood's Median Test:- performs a hypothesis test of the equality of population medians in a one-way design. Mood's median test, like the Kruskal-Wallis test, provides a nonparametric alternative to the usual one-way analysis of variance. Mood's median test is sometimes called a median test or sign scores test.
Mood's median test is robust against outliers and errors in data, and is particularly appropriate in the preliminary stages of analysis. Mood's median test is more robust against outliers than the Kruskal-Wallis test, but is less powerful (the confidence interval is wider, on the average) for analyzing data from many distributions, including data from the normal distribution.
·    Friedman:- performs a nonparametric analysis of a randomized block experiment and thus provides an alternative to the two-way analysis of variance.
Randomized block experiments are a generalization of paired experiments. The Friedman test is a generalization of the paired sign test with a null hypothesis of treatments having no effect. This test requires exactly one observation per treatment-block combination.
Tests for randomness.
Runs Tests test whether or not the data order is random. No assumptions are made about population distribution parameters. Use Stat > Quality Tools > Run Chart to generate a run chart and perform additional tests for randomness.
Procedures for calculating pairwise statistics
Pairwise Averages, Pairwise Differences, and Pairwise Slopes compute averages, differences, and slopes, respectively, for all possible pairs of values. These statistics are sometimes used in nonparametric statistical calculations.
Related Charting Tools
