Runs Test
overview
     how to     example     data     see also
Stat > Nonparametrics > Runs Test
Use Runs Test to see if a data order is random. Runs Test is a nonparametric test because no assumption is made about population distribution parameters. Use this test when you want to determine if the order of responses above or below a specified value is random. A run is a set of consecutive observations that are all either less than or greater than a specified value.
Variables: Select the columns containing the variables you want to test for randomness.
Above and below the mean: Choose to use the mean as the baseline to determine the number of runs.
Above and below: Choose to use a value other than the mean as the baseline to determine the number of runs, then enter a value.
Related Charting Tools
