Example of Mantel-Haenszel-Cochran Test
     interpreting results     session command
You want to assess the association between gender and smoking preference at each activity level (A lot, Moderate, or Slight) for individuals in your study, assuming there is no three-way interaction.
1    Open the worksheet EXH_TABL.MTW. If you have not already done so, set the value order for the variable Activity.
2    Choose Stat > Tables > Cross Tabulation and Chi-Square.
3    Choose Raw data (categorical variables).
4    In Rows, enter Gender.
5    In Columns, enter Smokes.
6    In Layers, enter Activity.
7    Under Display, check Counts.
8    Click Other Stats. Under Tests for 2x2 tables, check Mantel-Haenszel-Cochran test for multiple tables.
9    Click OK in each dialog box.
Session window output
Tabulated Statistics: Gender, Smokes, Activity
Results for Activity = Slight
Rows: Gender   Columns: Smokes
          No  Yes  All
Female     3    1    4
Male       3    2    5
All        6    3    9
Cell Contents:      Count
Results for Activity = Moderate
          No  Yes  All
Female    20    6   26
Male      22   13   35
All       42   19   61
Results for Activity = A lot
          No  Yes  All
Female     4    1    5
Male      12    4   16
All       16    5   21
Results for all 2x2 tables
Common odds ratio  1.85449
MHC statistic  DF   P-Value
     0.993340   1  0.318927
 Interpreting the results
The cells in the table contain the counts for Gender (row) and Smoke (column). A two-way table is displayed for each Activity level (Slight, Moderate, and A lot).
The common odds ratio of 1.85449 combines data from all three tables to estimate that the ratio of smokers to non-smokers among males is 1.85449 times the same ratio among females. The Mantel-Haenstzel-Cochran (MHC) test assumes that the odds ratio is the same for all three levels of activity. The MHC test has a p-value of 0.318927, indicating that the observed difference between males and females is not statistically significant.
Calendar with week numbers
US Federal Holidays
Australia Public Holidays
