Stat > Tables > Descriptive Statistics > Associated Variables
Displays summary statistics for associated variables.
Associated variables: Enter the columns containing the variables to be summarized.
Display
Means: Check to display cell means.
Medians: Check to display cell medians.
Minimums: Check to display cell minimums.
Maximums: Check to display cell maximums.
Sums: Check to display cell sums.
Standard deviations: Check to display cell standard deviations.
Data: Check to display all of the data in each cell.
N nonmissing: Check to display the number of nonmissing values.
N missing: Check to display the number of missing values.
Proportion of observations equal to: Check to display the proportion of observations with the specified value for each cell in the table, then specify the desired value. You must delete all missing values before using this option.
Proportion of observations between two numbers Check to display the proportion of observations which fall in the specified range for each cell in the table. You must delete all missing values before using this option.
Minimum: Enter the low value.
Maximum: Enter the high value.
