Analyze VariabilityMLE estimation method - P-Values |
Minitab provides two methods for fitting your model: least squares regression and maximum likelihood estimation. In many cases, the differences between the results of the two methods are minor. One approach is to use the p-values from the least squares analysis to choose the terms in the model, then use the coefficient estimates from the maximum likelihood analysis to calculate fits.
Coded Coefficients for Ln(Std)
Ratio Term Effect Effect Coef SE Coef Z-Value P-Value VIF Constant 0.3538 0.0791 4.48 0.000 Material -0.9607 0.3826 -0.4803 0.0791 -6.08 0.000 1.00 InjPress -0.1830 0.8328 -0.0915 0.0791 -1.16 0.247 1.00 InjTemp 0.0566 1.0582 0.0283 0.0791 0.36 0.720 1.00 CoolTemp -0.1204 0.8866 -0.0602 0.0791 -0.76 0.446 1.00 Material*InjPress -0.9927 0.3706 -0.4963 0.0791 -6.28 0.000 1.00 Material*InjTemp 0.1866 1.2051 0.0933 0.0791 1.18 0.238 1.00 Material*CoolTemp 0.0032 1.0032 0.0016 0.0791 0.02 0.984 1.00 InjPress*InjTemp -0.0775 0.9254 -0.0388 0.0791 -0.49 0.624 1.00 InjPress*CoolTemp -0.0800 0.9231 -0.0400 0.0791 -0.51 0.613 1.00 InjTemp*CoolTemp 0.0128 1.0129 0.0064 0.0791 0.08 0.935 1.00 |
In this example, the manufacturer already has the least squares regression results, which showed that material and the material by injection pressure interaction were significant with p-values equal to 0.000. The MLE results confirm the least squares regression results. The factor material and the interaction material by injection pressure are both significant with p-values equal to 0.000.
