Analyze Variability
MLE estimation method - Effects
The effects in the MLE estimated effects and coefficients table indicate the relative strength of the effects. Minitab provides two methods for fitting your model: least squares regression and maximum likelihood estimation. In many cases, the differences between the results of the two methods are minor. One approach is to use the p-values from the least squares analysis to choose the terms in the model, then use the coefficient estimates from the maximum likelihood analysis to calculate fits.
Example Output
Coded Coefficients for Ln(Std)
                             Ratio
Term                Effect  Effect     Coef  SE Coef  Z-Value  P-Value    VIF
Constant                             0.3538   0.0791     4.48    0.000
Material           -0.9607  0.3826  -0.4803   0.0791    -6.08    0.000   1.00
InjPress           -0.1830  0.8328  -0.0915   0.0791    -1.16    0.247   1.00
InjTemp             0.0566  1.0582   0.0283   0.0791     0.36    0.720   1.00
CoolTemp           -0.1204  0.8866  -0.0602   0.0791    -0.76    0.446   1.00
Material*InjPress  -0.9927  0.3706  -0.4963   0.0791    -6.28    0.000   1.00
Material*InjTemp    0.1866  1.2051   0.0933   0.0791     1.18    0.238   1.00
Material*CoolTemp   0.0032  1.0032   0.0016   0.0791     0.02    0.984   1.00
InjPress*InjTemp   -0.0775  0.9254  -0.0388   0.0791    -0.49    0.624   1.00
InjPress*CoolTemp  -0.0800  0.9231  -0.0400   0.0791    -0.51    0.613   1.00
InjTemp*CoolTemp    0.0128  1.0129   0.0064   0.0791     0.08    0.935   1.00
Interpretation
For the insulation data, the effect for Material from the maximum likelihood analysis is -0.9607 and the effect from the least squares analysis is -0.9598, a difference of only .0009. The effect from the maximum likelihood analysis of the interaction material by injection pressure is -0.9927 and the effect from the least squares analysis is -0.9918, a difference of only .0009. These results indicate that the difference between these two methods for the insulation data is negligible.
