Analyze Mixture DesignMixture Regression |
Use the p-values (P) to determine which of the effects in the model are statistically significant. To use the p-value, you need to:
- if the p-value is less than or equal to a, conclude that the effect is significant.
- if the p-value is greater than a, conclude that the effect is not significant.
Estimated Regression Coefficients for Flavor (component proportions)
Term Coef SE Coef T P VIF Emmentha 500 141.50 * * 24937 Gruyere -89 54.85 * * 613 Wine 395 143.73 * * 43038 Emmentha*Gruyere 1200 375.92 3.19 0.019 2655 Emmentha*Wine -1676 593.83 -2.82 0.030 102454 Gruyere*Wine -869 409.98 -2.12 0.078 7888 Emmentha*Temperat -572 141.50 -4.04 0.007 24937 Gruyere*Temperat 263 54.85 4.79 0.003 613 Wine*Temperat -568 143.73 -3.95 0.008 43038 Emmentha*Gruyere* Temperat -1440 375.92 -3.83 0.009 2655 Emmentha*Wine*Temperat 2388 593.83 4.02 0.007 102454 Gruyere*Wine*Temperat 1433 409.98 3.50 0.013 7888
* NOTE * Coefficients are calculated for coded process variables. |
For the fondue data, the regression table shows the following:
- Two-component blends with temperature: Each of the two-component blends have an interaction effect with Temperature. That is, the binary blending characteristics of all two-component blends differ depending in the serving temperature. These effects correspond to the following entries in the regression table:
- One-component blends with temperature: Each of the one-component blends has an interaction effect with Temperature. That is, the blending characteristics of all one-component blends differs depending in the serving temperature. These effects correspond to the following entries in the regression table:
- Emmentha*Gruyere: p-value = 0.019. In addition, the positive coefficient (1200) indicates that the two components act synergistically or are complementary. That is, the mean acceptance score for the blend is greater than you would obtain by calculating the simple mean of the two acceptance scores for each pure mixture.
- Emmentha*Wine: p-value = 0.030. In addition, the negative coefficient (-1676) indicates the two components are antagonistic towards one another. That is, the mean acceptance score is lower than you would obtain by calculating the simple mean of the two acceptance scores.
- Gruyere*Wine p-value = 0.078. The p-value is the least significant of the binary blends.
