Analyze Mixture DesignMixture Regression |
Use the p-values (P) in the analysis of variance table to determine which of the effects in the model are statistically significant. To use the p-value, you need to:
- if the p-value is less than or equal to a, conclude that the effect is significant.
- if the p-value is greater than a, conclude that the effect is not significant.
Analysis of Variance for Flavor (component proportions)
Source DF Seq SS Adj SS Adj MS F P Regression 11 3693.03 3693.029 335.730 152.04 0.000 Component Only Linear 2 3207.12 553.195 276.597 125.26 0.000 Quadratic 3 91.95 91.948 30.649 13.88 0.004 Emmentha*Gruyere 1 0.00 22.500 22.500 10.19 0.019 Emmentha*Wine 1 82.03 17.586 17.586 7.96 0.030 Gruyere*Wine 1 9.91 9.914 9.914 4.49 0.078 Component* Temperature Linear 3 294.55 53.799 17.933 8.12 0.016 Emmentha*Temperature 1 250.09 36.033 36.033 16.32 0.007 Gruyere*Temperature 1 37.66 50.654 50.654 22.94 0.003 Wine*Temperature 1 6.79 34.487 34.487 15.62 0.008 Quadratic 3 99.42 99.419 33.140 15.01 0.003 Emmentha*Gruyere*Temperature 1 24.46 32.400 32.400 14.67 0.009 Emmentha*Wine*Temperature 1 47.96 35.703 35.703 16.17 0.007 Gruyere*Wine*Temperature 1 26.99 26.995 26.995 12.23 0.013 Residual Error 6 13.25 13.249 2.208 Total 17 3706.28 |
For the fondue data, the analysis of variance table shows the following:
Regression is further broken into Components only and Components and Process Variable (Temperature), and then into the different orders of terms in the model - linear and quadratic.
- Components only
- Linear: The p-value for all linear terms is 0.000, indicating that at least one linear term has an impact on the mean response.
- Quadratic: The p-value for all quadratic terms is 0.004, indicating that at least one of the quadratic terms has an impact on the mean response. The Emmentha*Wine term (p-value = 0.030) and Emmentha*Gruyere term (p-value = 0.019) are significant.
- Component *Temperature
- Linear: The p-value for all linear terms is 0.016, indicating that at least one term has an impact on the mean response. The p-values for all of the individual linear terms are less than 0.05.
- Quadratic: The p-value for all quadratic terms is 0.003, indicating that at least one of the quadratic terms has an impact on the mean response. The p-values for all of the individual quadratic terms are less than 0.05.
