Analyze Mixture DesignMixture Regression |
The unusual observation table displays cases with standardized residuals with absolute values greater than 2. These cases do not follow the proposed regression equation well.
For unusual observations, you should investigate whether the data were recorded correctly, and whether the data collection process was affected by any other factors.
Residual plots can also help you examine the assumptions about the regression model. |
Unusual Observations for Flavor
Obs StdOrder Flavor Fit SE Fit Residual St Resid 10 10 58.000 58.799 1.436 -0.799 -2.10R 12 12 94.000 93.210 1.436 0.790 2.07R
R denotes an observation with a large standardized residual |
For the fondue data, two observations are unusual:
