Acceptance Sampling by Variables - Accept/Reject
Sample Criteria - Specification Limits
For variables data, a unit either meets specifications or does not meet specifications. Consequently, a sampled unit is either defective or not defective.
You need to specify at least one specification limit, upper or lower. However, many times, you will specify both limits because a unit is usually defective when it exceeds either specification limit (for example, a part can be either too big or too small).
Example Output
Sample Size                       259
Mean                              0.403108
Standard Deviation                0.0469204
Lower Specification Limit         0.395
Upper Specification Limit         0.415
Interpretation
For the camera lens data, you specify both an upper (0.415) and a lower specification (0.395) because a camera lens is defective when it is either too thick or too thin.
