Acceptance Sampling by Variables - Accept/RejectCalculated Criteria - Critical Distance (K Value) |
Z.LSL 0.172803 Z.USL 0.253452 Critical Distance (k Value) 3.44914 Maximum Standard Deviation (MSD) 0.0027533
Decision: Reject lot. |
When you created the sampling plan originally, Minitab determined the critical distance to be 3.44914 based on the lot size, the AQL, and the RQL. It will be used to determine whether the lot should be accepted or rejected.
