Gage Linearity and Bias StudyGraphs - Percent of Process Variation |
This chart is a graphical representation of %Linearity and %Bias.
You want both linearity and bias to be as small as possible. You also can compare the relative impact of both on the process variation.
For the parts data, the process variation is dominated by a linearity problem, not a bias problem.
