Gage R&R Study (Nested)
Summary
Any time you measure the results of a process you will see some variation. This variation comes from two sources: one, there are always differences between parts made by any process, and two, any method of taking measurements is imperfect. Thus, measuring the same part repeatedly does not result in identical measurements.
Use Gage R&R Study (Nested) to determine what portion of the variability in measurements may be due to the measurement system. Measurement system variability includes both variation due to the gage and operator-to-operator variability.
Nested Gage R&R is used for destructive tests when the following assumptions have been met:
·    All parts within a single batch are similar enough to claim they are the same part
·    Operators each measure from different batches
In a Gage R&R study, it is important that the measurements are done in a random order and that the parts selected provide a representative sample across the possible range of responses.
Data Description
Three operators each measured the temperature of three different parts three times. Note that the parts measured by each operator are unique.
Data: Temperature.MTW (available in the Sample Data folder).
Related Charting Tools
