Gage R&R Study (Nested)ANOVA Method |
Nested ANOVA (analysis of variance) tells you if different levels of two factors result in different average values of a response variable.
The nested ANOVA table lists the following sources of variability:
You want to see if the p-value associated with each source is less than the chosen level of significance. This would indicate that the source contributes significantly to the measurement variability.
The results displayed in this ANOVA table will be used to compute the Gage R&R.
Operator 2 529 264.3 0.02409 0.976 Part (Operator) 6 65820 10970.0 1.47498 0.242 Repeatability 18 133873 7437.4 Total 26 200222 |
For the parts data, the p-value for Operator (P = 0.976) shows you that the average temperature is probably not dependent upon the operator taking measurements at the a = 0.05 level of significance.
