Capability Analysis - Normal
Graphs - Process Data
The process data section of the capability analysis graph consists of the following:
·    Upper and lower specification limits (USL and LSL) - the limits you specified.
·    Target - the target value you specified.
·    Mean - the mean of all measurements, which is where the process is centered.
·    Sample N - the total number of observations in your data.
·    Within standard deviation - a measure of the variation within subgroups.
·    Overall standard deviation - a measure of the variation of all the measurements.
A substantial difference between the overall and within capability indices may indicate that the process is out of control, or the sources of variation are not estimated by the within-subgroup component of variation. For the piston data, the within and overall capability indices are very close to each other.
Example Output
Interpretation
For the piston data:
·    Upper and lower specification limits (USL and LSL) - the LSL is 73.95 and the USL is 74.05.
·    Target - the target is 74.
·    Mean - The mean is 74. Note that the mean is very close to the target of 74.0, which implies that the process is centered on target.
·    Sample N - 125 pistons were measured.
·    Within standard deviation - The within standard deviation is 0.0100509.
·    Overall standard deviation - The overall standard deviation is 0.0101989.
The within and overall capability indices are very close to each other.
