Capability Analysis - NormalGraphs - Potential Capability |
The potential (within) capability indices are associated with the within-subgroup standard deviation.
The industry guidelines determine whether the process is capable. A generally accepted minimum value for the indices is 1.33.
These indices reflect how the process could perform relative to the specification limits, if the shifts and drifts between subgroups could be eliminated. The capability indices consist of the following:
A substantial difference between the overall and within capability indices may indicate that the process is out of control, or the sources of variation are not estimated by the within-subgroup component of variation. For the piston data, the within and overall capability indices are very close to each other.
For the piston data, Cp is 1.66, which indicates that the specification spread is 1.66 times greater than the 6-s spread in the process.
Cp (1.66) and Cpk (1.62) are very close to one another, indicating that the process is centered on target. The capability indices are greater than 1.33, indicating that the process is centered on target and capable of producing pistons that conform to specifications.
