Capability Analysis - Between/Within
Graphs - Process Data
The process data section of the capability analysis graph consists of the following:
·    Upper and lower specification limits (USL and LSL) - the limits you specified.
·    Target - the target value you specified. Mean - the mean of all measurements, which is where the process is centered.
·    Sample N - the total number of observations in your data.
·    Overall standard deviation - a measure of the variation of all the measurements.
·    Between standard deviation - a measure of the variation between subgroups.
·    Within standard deviation - a measure of the variation within subgroups.
·    B/W standard deviation - a measure of the between/within standard deviation, calculated by combining the between- and within-subgroup variation.
Example Output
Interpretation
For the coating data:
·    Upper and lower specification limits (USL and LSL) - LSL is 47 and the USL is 53.
·    Target - The target is 50.
·    Mean - The mean is 49.8829. Note that the mean is very close to the target of 50.0, which implies that the process is centered on target.
·    Sample N - 75 coatings were measured.
·    Overall standard deviation - The overall standard deviation is 0.838488.
·    Between standard deviation - The between standard deviation is 0.685488.
·    Within standard deviation - The within standard deviation is 0.40608.
·    B/W standard deviation - The b/w standard deviation is 0.79674.
Related Charting Tools
