Capability Analysis - Between/WithinGraphs - Between/Within Capability |
The between/within capability section includes capability indices associated with the B/W (between and within) standard deviation.
The industry guidelines determine whether the process is capable. A generally accepted minimum value for the indices is 1.33.
These indices reflect how the process could perform relative to the specification limits, if the shifts and drifts of the process could be eliminated. The capability indices consist of the following:
Use CPL and CPU when you have a single-sided specification limit. For example, if you want a cable to meet a minimum strength, you might compare the process to the lower specification limit.
A substantial difference between the overall and B/W capability indices may indicate that the process is out of control. For the coating data, the B/W and overall capability indices are very close to each other.
For the coating data, Cp is 1.26, which indicates that the specification spread is 1.26 times greater than the 6-s spread in the process.
Cp (1.26) and Cpk (1.21) are very close to one another, indicating that the process is approximately centered. The differences are due to the mean being slightly below the target value.
