One-Way ANOVAGrouping Information Table - Fisher's Least Significant Difference (LSD) |
Fisher's LSD method compares the means for each pair of factor levels using the individual error rate you select. Note that the family error rate, which is the probability of making one or more type I errors for the entire set of comparisons, will be higher than the error rate for each individual comparison.
The grouping information table highlights the significant and nonsignificant comparisons. The table includes the following information.
To determine a likely range for the difference between two means, use the interval plot for differences of means.
Grouping Information Using Fisher Method
Paint N Mean Grouping Blend 4 6 18.067 A Blend 1 6 14.733 A B Blend 3 6 12.983 B C Blend 2 6 8.567 C
Means that do not share a letter are significantly different. |
The grouping information for the paint hardness data shows that group A contains Blends 1 and 4; group B contains Blends 1 and 3; and, group C contains Blends 2 and 3. Blends 1 and 3 are in two groups. Factor levels within a group are not significantly different from each other. Because the following factor level combinations do not share a letter, their means are significantly different:
Independent, standards-based quality expertise on the ground in China — know exactly what you are buying before it ships.
Backed by PinZhi.org, the community of 130,000+ quality professionals across every manufacturing sector.
Visit verify.pinzhi.org ↗Free online chart generators for statistical analysis:
