One-Way ANOVAGrouping Information Table - Dunnett's Comparisons with a Control |
Dunnett's method compares the mean of each level with the mean of a control level. The control level is usually a standard against which you want to compare all other levels.
This method uses a family error rate (often called familywise error rate) to control the rate of type I error. The family error rate is the probability of making one or more type I errors for the entire set of comparisons. Dunnett's method adjusts the error rate for individual comparisons (individual error rate), based on the family error rate you choose.
The grouping information table highlights the significant and nonsignificant comparisons. The table includes the following information.
To determine a likely range for the difference between two means, use the interval plot of simultaneous confidence intervals.
Grouping Information Using Dunnett Method
Paint N Mean Grouping Blend 1 (control) 6 14.733 A Blend 4 6 18.067 A Blend 3 6 12.983 A Blend 2 6 8.567
Means not labeled with letter A are significantly different from control level mean. |
Blend 1 is the control group. The grouping information for the paint hardness data shows that only Blend 2 does not belong to group A and, therefore, is significantly different from the control group. Blends 1, 3, and 4 produce equivalent paint hardness while Blend 2 is significantly softer.
Independent, standards-based quality expertise on the ground in China — know exactly what you are buying before it ships.
Backed by PinZhi.org, the community of 130,000+ quality professionals across every manufacturing sector.
Visit verify.pinzhi.org ↗Free online chart generators for statistical analysis:
