One-Way ANOVAGrouping Information Table - Games-Howell Method |
The Games-Howell method compares the means for each pair of factor levels using a family error rate (often called familywise error rate) to control the rate of type I error. The family error rate is the probability of making one or more type I errors for the entire set of comparisons. The Games-Howell method adjusts the individual confidence level, based on the family error rate you choose.
This method is only available if you do not assume that all populations have equal variances.
The grouping information table highlights the significant and nonsignificant comparisons. The table includes the following information.
To determine a likely range for the difference between two means, use the interval plot for differences of means.
Grouping Information Using the Games-Howell Method and 95% Confidence
Paint N Mean Grouping Blend 4 6 18.07 A Blend 1 6 14.73 A B Blend 3 6 12.98 A B Blend 2 6 8.57 B
Means that do not share a letter are significantly different. |
The grouping information for the paint hardness data shows that group A contains Blends 1, 3, and 4 while group B contains Blends 1, 2, and 3. Blends 1 and 3 are in both groups. Factor levels within a group are not significantly different from each other. Because Blends 2 and 4 do not share a letter, Blend 4 has a significantly higher mean than Blend 2.
Independent, standards-based quality expertise on the ground in China — know exactly what you are buying before it ships.
Backed by PinZhi.org, the community of 130,000+ quality professionals across every manufacturing sector.
Visit verify.pinzhi.org ↗Free online chart generators for statistical analysis:
