General Linear Model (GLM)Unusual Observations Table - Standardized Residuals |
The unusual observation table displays observations that have a disproportionate impact on the general linear model. These points are important to identify because they can produce misleading results. For example, a significant coefficient may appear to be nonsignificant.
There are two types of influential observations.
These cases do not follow the proposed regression equation well. However, it is expected that you will have some unusual observations. For example, based on the criteria for large residuals, you would expect roughly 5% of your observations to be flagged as having a large residual.
For influential observations, you should investigate whether the data were recorded correctly, and whether the data collection process was affected by any other factors. To determine the extent of influence, you can fit the model with and without an influential observation and compare the coefficients, p-values, R2, and other model summary values.
If the analysis indicates that there are many unusual observations, the model will most likely exhibit a significant lack-of-fit. That is, the model does not adequately describe the relationship between the factors and the response variable.
Fits and Diagnostics for Unusual Observations
Obs Salary Fit Resid Std Resid 39 2.3000 2.5500 -0.2500 -2.40 R 40 2.8000 2.5500 0.2500 2.40 R
R Large residual |
For the salary data, two observations, 39 and 40, have standardized residuals with absolute values greater than 2 (-2.40 and 2.40). Because there are 45 observations in this study, you expect to see two or three unusual observations. You should investigate these two observations.
Residual plots can also help you examine the assumptions about the general linear model. |
