General Linear Model (GLM)Means - Least Squares Means |
The means table displays the fitted mean and standard error of the mean (SE Mean) for each level of the factors or interaction terms that you specify.
To determine whether the differences between means are statistically significant, you should conduct multiple comparisons of the means.
Means
Subject 1 2.1500 0.0522 2 2.8067 0.0411 3 3.1133 0.0479 4 2.8400 0.0539 Degree 1 2.3875 0.0488 2 2.4675 0.0444 3 3.3275 0.0325 |
The results of the salary analysis indicate that:
