General MANOVAUnivariate Statistics - ANOVA Table for Quality |
When you do a general MANOVA, you can choose to calculate the univariate statistics to examine the individual responses.
The most important statistic in the analysis of variance table is the p-value (P), which exists for each term in the model (except for the error term). The p-value for a term tells you whether the effect for that term is significant:
If a factor is significant, the level means for the factor are significantly different from each other.
If an interaction term is significant, the effects of each factor are different at each level of the other factors. For this reason, you should not analyze the individual effects of terms involved in significant higher-order interactions.
Analysis of Variance for Quality, using Adjusted SS for Tests
Source DF Seq SS Adj SS Adj MS F P Method 1 8.859 9.220 9.220 7.53 0.008 Plant 2 6.763 7.057 3.529 2.88 0.064 Method*Plant 2 0.707 0.707 0.354 0.29 0.750 Error 56 68.590 68.590 1.225 Total 61 84.919 |
In the door lock analysis, you assessed the effects of method, plant, and the method- by-plant interaction for the quality response. Assuming that you chose the common a-level of 0.05 for the test, the results indicate that:
