General MANOVAUnivariate Statistics - S, R-Sq and R-Sq(Adj) Values for Quality |
S, R
and adjusted R
are measures of how well the model fits the data. These values
can help you select the model with the best fit.
(R-Sq) describes the amount of variation in the observed
response values that is explained by the predictor(s).
R
always increases with additional predictors. For example,
the best five-predictor model will always have a higher R
than the best four-predictor model. Therefore, R
is most useful when comparing models of the same size.
is a modified R
that has been adjusted
for the number of terms in the model. If you include unnecessary terms,
R
can be artificially high. Unlike R
, adjusted
R
may get smaller when you add terms to the model. Use
adjusted R
to compare models with different numbers of predictors.
For the door lock data, S is 1.10672, R
is 19.23%,
and the adjusted R
equals 12.02%. The low adjusted R
value indicates
that the univariate model for quality does not fit the data well.
If you are comparing different door lock quality models, then you generally
look for models that minimize S and maximize the two R
values.
