General MANOVA
MANOVA for Method - Matrices
Minitab displays three matrices to examine variability, error, and partial correlations.
Use the SSCP matrix to assess the partitioning of variability in the same way you would look at univariate sums of squares. The matrix labeled as SSCP Matrix for model term is the hypothesis sums of squares and cross-products matrix, or H, for the responses with the specified model term. The diagonal elements are the univariate ANOVA sums of squares for the model term for each response. The off-diagonal elements of this matrix are the cross products.
The matrix labeled as SSCP Matrix for Error is the error sums of squares and cross-products matrix, or E. The diagonal elements of this matrix are the univariate ANOVA error sums of squares for the response variables. The off-diagonal elements of this matrix are the cross products. This matrix is displayed once, after the SSCP matrix for the first model term.
Use the matrix of partial correlations, labeled as Partial Correlations for the Error SSCP Matrix, to assess how the response variables are related. The off-diagonal elements are the correlations among the residuals or, equivalently, the correlations among the responses conditioned on the model. If the correlation between the responses is low, you may want to perform univariate ANOVA tests for the individual responses. This matrix is displayed once, after the SSCP matrix for error.
Example Output
SSCP Matrix (adjusted) for Method
           Usability  Quality
Usability      29.07   16.372
Quality        16.37    9.220
SSCP Matrix (adjusted) for Error
           Usability  Quality
Usability      49.75    29.45
Quality        29.45    68.59
           Usability  Quality
Usability    1.00000  0.50413
Quality      0.50413  1.00000
Interpretation
For the door lock data, 29.07 and 9.220 are the univariate sums of squares for usability and quality for method. The univariate error sums of squares for usability and quality are 49.75 and 68.59. The partial correlation between usability and quality is 0.50413, indicating that the response variables are moderately correlated.
Related Charting Tools
