General MANOVA
MANOVA for Method - Eigen Analysis
Use the eigen analysis to assess how the response means differ among the levels of the different model terms. The eigen analysis is of E-1 H, where E is the error SSCP matrix and H is the response variable SSCP matrix. These eigenvalues are used to calculate the MANOVA tests. Place the highest importance on the eigenvectors that correspond to high eigenvalues.
Example Output
EIGEN Analysis for Method
Eigenvalue  0.5848  0.00000
Proportion  1.0000  0.00000
Cumulative  1.0000  1.00000
Eigenvector          1         2
Usability     0.144062  -0.07870
Quality      -0.003968   0.13976
Interpretation
For the door lock data, the first eigenvalue for method (0.5848) is greater than the second eigenvalue (0.00000), so place higher importance on the first eigenvector. The first eigenvector for method is 0.144062, -0.003968. The highest absolute value within this vector is for the response usability, implying that usability means have the largest difference between the factor levels for method.
