General MANOVA
MANOVA for Method-By-Plant
Interaction - SSCP Matrix
Use the SSCP matrix to assess the partitioning of variability in a similar way as you would look at univariate sums of squares. The matrix labeled as SSCP Matrix for model term is the hypothesis sums of squares and cross-products matrix, or H, for the responses with the specified model term. The diagonal elements are the univariate ANOVA sums of squares for the model term for each response. The off-diagonal elements of this matrix are the cross products.
Example Output
SSCP Matrix (adjusted) for Method*Plant
           Usability  Quality
Usability      7.099   1.7600
Quality        1.760   0.7074
Interpretation
For the door lock data, 7.099 and 0.7074 are the univariate sums of squares for usability and quality for the method-by-plants interaction.
