General MANOVAMANOVA for Method-By-Plant |
Use the eigen analysis to assess how the response means differ among the levels of the different model terms. The eigen analysis is of E-1 H, where E is the error SSCP matrix and H is the response variable SSCP matrix. These eigenvalues are used to calculate the MANOVA tests. Place the highest importance on the eigenvectors that correspond to high eigenvalues.
EIGEN Analysis for Method*Plant
Eigenvalue 0.1597 0.00473 Proportion 0.9712 0.02879 Cumulative 0.9712 1.00000
Eigenvector 1 2 Usability 0.16117 -0.03115 Quality -0.04629 0.13193 |
For the door lock data, the first eigenvalue for Method*Plant (0.1597) is greater than the second eigenvalue (0.00473), so place higher importance on the first eigenvector. The first eigenvector for Method*Plant is 0.16117, -0.04629. The highest absolute value within this vector is for the response usability, implying that usability means have the largest difference between the factor levels for the method-by-plants interaction.
