One Variance
Confidence intervals - Chi-square method
Use the chi-square method if you can safely assume that your sample comes from a normally distributed population. These two confidence intervals provide ranges of values that are likely to contain the unknown population standard deviation and variance, respectively.
Example Output
Method
The chi-square method is only for the normal distribution.
The Bonett method is for any continuous distribution.
Statistics
Variable   N  StDev  Variance
Length    50  0.871     0.759
95% Confidence Intervals
                                         CI for
Variable  Method       CI for StDev     Variance
Length    Chi-Square  (0.728, 1.085)  (0.529, 1.178)
          Bonett      (0.704, 1.121)  (0.496, 1.257)
Interpretation
In the lumber yard example, if the data are normal, then the standard deviation of the length of all beams from the lumber yard is likely to be between 0.728 cm and 1.085 cm. The variance of that length is likely to be between 0.529 cmimage\squared.gif and 1.178 cmimage\squared.gif.
