One VarianceConfidence intervals - Bonett method |
Use the Bonett method if your sample data are continuous, but do not come from a normally distributed population. These two confidence intervals provide ranges of values that are likely to contain the unknown population standard deviation and variance, respectively.
Method
The chi-square method is only for the normal distribution. The Bonett method is for any continuous distribution.
Statistics
Length 50 0.871 0.759
95% Confidence Intervals
Variable Method CI for StDev Variance Length Chi-Square (0.728, 1.085) (0.529, 1.178) Bonett (0.704, 1.121) (0.496, 1.257) |
In the lumber yard example, if the data are nonnormal, then the standard
deviation of the length of all beams from the lumber yard is likely to
be between 0.704 cm and 1.121
cm. The variance of that length is likely to be between 0.496 cm
and 1.257
cm
