Equivalence Test with Paired DataMethod |
The method table shows the details of the analysis, such as which sample is the test sample and which is the reference sample. If you test the difference between the means and specify the limits as a proportion of the reference mean, then Minitab also shows the calculations for the equivalence interval.
Method
Test mean = mean of New Reference mean = mean of Leading Brand |
For the contact lens analysis, the test sample is New, and the reference sample is Leading Brand.
