Equivalence Test with Paired Data
Descriptive Statistics
The table of descriptive statistics shows the sample sizes. The table also shows the means, the standard deviations, and the standard errors of the mean for your samples.
Example Output
Variable        N    Mean   StDev  SE Mean
New            14  88.604  1.5578  0.41634
Leading Brand  14  88.724  1.5907  0.42514
Interpretation
For the contact lens data, the mean for the new cleaning solution is 88.604. The mean for the leading brand is 88.724.
The variability for each solution is similar. The standard deviation for the new solution is 1.5578. The standard deviation for the leading brand is 1.5907.
