Binary Fitted Line PlotOdds Ratio |
One advantage of the logit link function is that it provides an estimate of the odds ratio for each predictor in the model. The larger the odds ratio, the greater are the odds that a predictor affects the binary response relative to the predictor's reference level. An odds ratio of 1 indicates no association between the predictor and response.
Odds Ratios for Continuous Predictors
Unit of Odds Predictor Change Ratio 95% CI Length 7 0.719 (0.43, 1.19) |
For the health care center data, the logit link was used. Although the units of the data are 1 day, the odds ratio is for 7 days. Therefore, the odds ratios indicates that a patient who stays one week longer than another patient has an odds 0.719 times smaller that the center discharges the patient for other reasons.
