Gage Linearity and Bias StudyGraphs - Gage Linearity |
The gage linearity table consists of the following:
, which is the proportion of the variation in the average bias
that can be explained by its linear relationship with the master part measurements.
If the R
value is not close to 1, the relationship is
not linear and linearity cannot be assessed. A non-linearity problem may
exist.
For the parts data, the %linearity is relatively large (13.2%), which indicates a problem. Smaller parts tend to measure too high, while larger parts tend to measure too low.
Because the R value is high (71.4%),
you can assume that the relationship between the master part measurement
and bias is close to linear. It is reasonable to assess linearity for
the parts data.
