Gage R&R Study (Nested)ANOVA Method |
The chart consists of the following:
Because the parts chosen for a Gage R&R study should represent the entire range of possible parts, this graph should ideally show lack-of-control. Lack-of-control exists when many points are above the upper control limit and/or below the lower control limit.
For the temperature data, there are no points beyond the control limits for each operator. This indicates that the measuring system is inadequate.
