Binary Fitted Line Plot
Unusual Observations Table - Standardized Residuals
The unusual observation table displays cases that meet one of two criteria:
For unusual observations, you should investigate whether the data were recorded correctly, and whether the data collection process was affected by any other factors.
Example Output
Fits and Diagnostics for Unusual Observations
        Observed
Obs  Probability     Fit    Resid  Std Resid
 32       0.0000  0.0637  -0.3627      -0.39     X
 58       1.0000  0.1486   1.9526       2.02  R
R  Large residual
X  Unusual X
Interpretation
For the health care center data, two observations, 32 and 58, are unusual. Observation 32 has a large leverage value. Observation 58 has a standardized residual with absolute value greater than 2 (2.02). Observation 58 does not follow the proposed regression equation well. You can fit the model with and without these observations to explore how much influence the observations have on the results.
Note
Residual plots can also help you examine the assumptions about the regression model.
