查看: 854|回复: 0
IEC 62979:2017 Photovoltaic modules - Bypass diode - Thermal runaway test
发表于 2017-8-14 17:18:51 | 显示全部楼层 |阅读模式
IEC 62979:2017(E) provides a method for evaluating whether a bypass diode as mounted in the module is susceptible to thermal runaway or if there is sufficient cooling for it to survive the transition from forward bias operation to reverse bias operation without overheating. This test methodology is particularly suited for testing of Schottky barrier diodes, which have the characteristic of increasing leakage current as a function of reverse bias voltage at high temperature, making them more susceptible to thermal runaway.
Publication type        International Standard
Publication date        2017-08-10
Edition        1.0
TC/SC        TC 82 - Solar photovoltaic energy systemsrss
ICS        27.160 - Solar energy engineering
Stability date          2019
Pages        13
File size        1342 KB
GMT+8, 2026-10-6 22:16 , Processed in 0.081165 second(s), 8 queries , Gzip On, Redis On.
