查看: 945|回复: 0
IEC 62287-1:2017 Carrier-sense time division multiple access (CSTDMA) techniques
管理员
发表于 2017-8-14 18:08:21 | 显示全部楼层 |阅读模式
IEC 62287-1:2017 Maritime navigation and radiocommunication equipment and systems - Class B shipborne equiment of the automatic identification system (AIS) - Part 1: Carrier-sense time division multiple access (CSTDMA) techniques
IEC 62287-1:2017 specifies the minimum operational and performance requirements, methods of testing and required test results for Class B shipborne automatic identification system (AIS) equipment using carrier-sense time division multiple access (CSTDMA) techniques. This document takes into account other associated IEC International Standards and existing national standards, as applicable.
It is applicable for AIS equipment used on craft that are not covered by the mandatory carriage requirement of AIS under SOLAS Chapter V.
An AIS station intended to operate in receive-only mode is not considered a Class B shipborne mobile AIS station.
This edition includes the following significant technical change with respect to the previous edition: in the synchronisation method, addition of a direct method for synchronisation from an internal UTC source.
Publication type        International Standard
Publication date        2017-01-20
Edition        3.0
TC/SC        TC 80 - Maritime navigation and radiocommunication equipment and systemsrss
ICS        47.020.70 - Navigation and control equipment
Stability date        2023
Hardcopy        190  pages
File size        1543 KB
GMT+8, 2026-10-6 22:16 , Processed in 0.018322 second(s), 9 queries , Gzip On, Redis On.
